Mounting the Antenna Under the Deck
NOTICE
Before attaching the under-deck mounting bracket to the surface, verify the included screws will not penetrate the surface. If the included screws are too long, you must purchase surface-appropriate screws to complete the installation.
Before you permanently mount the antenna, you must test the mounting location for correct operation (Antenna Mounting Considerations).
Because the antenna cannot acquire signals through metal, it must be mounted under a fiberglass surface only.
  1. Place the adhesive pads Callout number 1 on the under-deck mounting bracket Callout number 2.
    Under-surface mount with callouts
  2. Place the antenna in the under-deck mounting bracket.
  3. Adhere the under-deck mounting bracket to the mounting surface.
  4. Secure the under-deck mounting bracket to the mounting surface with screws.
  5. Connect the cable to the antenna Callout number 3.
  6. Route the cable away from sources of electronic interference.
GUID-A5780D3E-B2B0-4C60-8835-94BCF0D13E14 v5
January 2025
