NMEA 0183 Connection Considerations
  • The installation instructions provided with your NMEA® 0183 compatible device should contain the information you need to identify the transmitting (Tx) and receiving (Rx) A (+) and B (-) wires.
  • When connecting NMEA 0183 devices with two transmitting and two receiving wires, it is not necessary for the NMEA 2000® bus and the NMEA 0183 device to connect to a common ground.
  • When connecting a NMEA 0183 device with only one transmitting (Tx) wire or with only one receiving (Rx) wire, the NMEA 2000 bus and the NMEA 0183 device must be connected to a common ground.
GUID-A5780D3E-B2B0-4C60-8835-94BCF0D13E14 v5
January 2025
