Mounting the Antenna with the Cable Routed Through the Pole
Before you permanently mount the antenna, you must test the mounting location for correct operation (Antenna Mounting Considerations).
  1. Position a standard 1 in. OD, 14 threads per inch, pipe-threaded pole (not included) in the selected location, and mark the approximate center of the pole.
  2. Drill a hole using a 19 mm (3/4 in.) drill bit for the cable to pass through.
  3. Fasten the pole to the boat.
  4. Thread the pole-mount adapter onto the pole.
    Do not overtighten the adapter.
  5. Route the cable through the pole and connect it to the antenna.
  6. Place the antenna on the pole-mount adapter and twist it clockwise to lock it in place.
  7. Secure the antenna to the adapter with the included M3 set screw Callout number 1.
    Pole mount with cable routed through pole with callouts
  8. With the antenna installed on the pole mount, fill the vertical cable slot Callout number 2 with a marine sealant (optional).
  9. Route the cable away from sources of electronic interference.
GUID-A5780D3E-B2B0-4C60-8835-94BCF0D13E14 v5
January 2025
