Video Connector Gasket Considerations
Rubber gaskets are included for all DVI and VGA connections on the device. These gaskets must be installed between each DVI or VGA port and cable connector to avoid damage to the connectors. When making DVI or VGA connections, observe these considerations.
Exploded view of video connection with gasket
  • Blue gaskets are included for use with DVI connections.
  • Gray gaskets are included for use with VGA connections.
  • When installing the gasket between a VGA cable connector and port, the arrow on the side of the seal must point toward the device.
GUID-A5780D3E-B2B0-4C60-8835-94BCF0D13E14 v5
January 2025
