Specifications
Eight-Inch Models
Specification
Measurement
Dimensions (W×H×D)
265 × 190 × 115 mm (107/16 × 731/64 × 417/32 in.)
Display size (W×H)
171 × 130 mm (647/64 × 51/8 in.)
Weight
3.23 kg (7.12 lb.)
Max. power usage at 10 Vdc
28 W
Typical current draw at 12 Vdc
1.3 A
Max. current draw at 12 Vdc
2.8 A
Compass-safe distance
310 mm (12.2 in.)
Twelve-Inch Models
Specification
Measurement
Dimensions (W×H×D)
333 × 247 × 97 mm (137/64 × 923/32 × 313/36 in.)
Display size (W×H)
245 × 184 mm (921/32 × 7¼ in.)
Weight
4.95 kg (10.91 lb.)
35 W
1.6 A
3.5 A
460 mm (18.11 in.)
Fifteen-Inch Models
Specification
Measurement
Dimensions (W×H×D)
403 × 306 × 94 mm (157/8 × 123/64 × 345/64 in. )
Display size (W×H)
(304 × 228 mm (1131/32 × 863/64 in.)
Weight
7.6 kg (16.76 lb.)
47 W
2.5 A
4.7 A
460 mm (18.11 in.)
All Models
Specification
Measurement
Temperature range
From 5° to 131°F (from -15° to 55°C)
Material
Die-cast aluminum and polycarbonate plastic
Input power
10 to 35 Vdc
Fuse
7.5 A, 42 V fast-acting
NMEA 2000® LEN @ 9 VDC
2
NMEA 2000 Draw
75 mA max.
GUID-A5780D3E-B2B0-4C60-8835-94BCF0D13E14 v5
January 2025
