NMEA 2000 Considerations
NOTICE
If you have an existing NMEA 2000® network on your boat, it should already be connected to power. Do not connect the NMEA 2000 power cable to an existing NMEA 2000 network, because only one power source should be connected to a NMEA 2000 network.
NOTICE
If you are installing a NMEA 2000 power cable, you must connect it to the boat ignition switch or through another in-line switch. NMEA 2000 devices will drain your battery if the NMEA 2000 power cable is connected to the battery directly.
This device can connect to a NMEA 2000 network on your boat to share data from NMEA 2000 compatible devices such as a GPS antenna or a VHF radio. The included NMEA 2000 cables and connectors allow you to either connect the device to your existing NMEA 2000 network or create a basic NMEA 2000 network if needed.
If you are unfamiliar with NMEA 2000, you should read the “NMEA 2000 Network Fundamentals” chapter of the Technical Reference for NMEA 2000 Products. You can find this document using the “Manuals” link on the product page for your device at www.garmin.com.
The port labeled NMEA 2000 is used to connect the device to a standard NMEA 2000 network. The ports labeled ENGINE and HOUSE are reserved for future use and should not be connected to a standard NMEA 2000 network.
Wiring diagram with callouts
Item
Description
Callout number 1
NMEA 2000 compatible Garmin® device
Callout number 2
GPS antenna
Callout number 3
Ignition or in-line switch
Callout number 4
Callout number 5
NMEA 2000 drop cable
Callout number 6
12 Vdc power source
Callout number 7
NMEA 2000 terminator or backbone cable
Callout number 8
NMEA 2000 T-connector
Callout number 9
GUID-A5780D3E-B2B0-4C60-8835-94BCF0D13E14 v5
January 2025
