Mounting Considerations
NOTICE
This device should be mounted in a location that is not exposed to extreme temperatures or conditions. The temperature range for this device is listed in the product specifications. Extended exposure to temperatures exceeding the specified temperature range, in storage or operating conditions, may cause device failure. Extreme-temperature-induced damage and related consequences are not covered by the warranty.
Using the included hardware and template, you can mount the device using one of two methods. You can use the included bracket and hardware to bail mount the device, or you can use the included template and hardware to flush mount the device in the dashboard. If you want to mount the device using an alternative method where it appears flat with the front of the dashboard, you must purchase a flat-mount kit (sold separately, with professional installation recommended) from your Garmin® dealer.
When selecting a mounting location, observe these considerations.
NOTE: Not all mounting methods are available for all device models. See the specific mounting-type section for more details about your model.
  • The location should provide optimal viewing as you operate your boat.
  • The location should allow for easy access to all device interfaces, such as the keypad, touchscreen, and card reader, if applicable.
  • The location must be strong enough to support the weight of the device and protect it from excessive vibration or shock.
  • To avoid interference with a magnetic compass, the device should not be installed closer to a compass than the compass-safe distance value listed in the product specifications.
  • The location must allow room for the routing and connection of all cables.
GUID-A5780D3E-B2B0-4C60-8835-94BCF0D13E14 v5
January 2025
