Station Connection Considerations
This device can be set up in conjunction with other compatible
Garmin® devices to work together as a station. When planning stations on your boat, observe these considerations.
Devices earlier than the GPSMAP® 8000 series and GPSMAP 8500 series cannot be used in a station.
Although it is not necessary, it is recommended that you install all of the devices you plan to use in one station near each other.
No special connections are necessary to create a station, as long as all of the devices are connected to the Garmin Marine Network (Garmin Marine Network Considerations).
Stations are created and modified using the device software. See the owner's manual provided with the device for more information.
Parent Topic: Cable and Connection Considerations
