Advanced Map Settings
Press PAGE to scroll to the map page, and press MENU. Select Map Setup > Advanced Setup.
Auto Zoom
Automatically selects the appropriate zoom level for optimal use on your map. When Off is selected, you must zoom in or out manually.
Detail
Sets the amount of detail shown on the map. Showing more detail may cause the map to redraw more slowly.
Shaded Relief
Shows detail relief on the map, if available, or turns off shading.
Vehicle
Sets the position icon, which represents your position on the map. The default icon is a small blue triangle.
Zoom Levels
Adjusts the zoom level at which map items appear. The map items do not appear when the map zoom level is higher than the selected level.
Text Size
Sets the text size for map items.
GUID-11021D65-32D1-4558-A83E-F7F74FF88D7E v6
February 2025
