Heading Settings
Press PAGE to scroll to the compass page, and press MENU. Select Heading Setup.
Display
Sets the directional heading on the compass to letters, degrees, or milliradians.
North Reference
Sets the north reference used on the compass (Setting the North Reference).
Go To Line (Pointer)
Sets the behavior of the pointer that appears on the map. Bearing points in the direction of your destination. Course (CDI) shows your relationship to the course line leading to the destination.
Compass
Automatically switches from an electronic compass to a GPS compass when you are traveling at a higher rate of speed for a period of time.
Calibrate Compass
Allows you to calibrate the compass if you experience irregular compass behavior. For example, after moving long distances or after extreme temperature changes (Calibrating the Compass).
GUID-11021D65-32D1-4558-A83E-F7F74FF88D7E v6
February 2025
