Changing the Units of Measure
- Press MENU twice to open the main menu.
- Select .
Select an option:
To change the unit of measure for speed and distance, select Speed/Distance.
To change the unit of measure for vertical speed, select Vertical Speed.
To change the unit of measure for elevation, select .
To change the unit of measure for depth, select .
To change the unit of measure for temperature, select Temperature.
To change the unit of measure for pressure, select Pressure.
- Select a unit of measure.
Parent Topic: Setup Menu
