Touchscreen Tips Before you go for a run, you should practice using the touchscreen. Select or , and tap the touchscreen to unlock the device. Tap the touchscreen to view the next data screen. Select the touchscreen to confirm messages and alerts. Select the top and bottom of the touchscreen to scroll through menus, options, and settings. You can also swipe to scroll though the items. You can hold the top and bottom of the touchscreen to scroll faster. From a data screen, hold a data field to change it. Select to close a message or confirm a choice. You can also select to close a message. Make each touchscreen selection a separate action. Parent Topic: Introduction
Touchscreen Tips Before you go for a run, you should practice using the touchscreen. Select or , and tap the touchscreen to unlock the device. Tap the touchscreen to view the next data screen. Select the touchscreen to confirm messages and alerts. Select the top and bottom of the touchscreen to scroll through menus, options, and settings. You can also swipe to scroll though the items. You can hold the top and bottom of the touchscreen to scroll faster. From a data screen, hold a data field to change it. Select to close a message or confirm a choice. You can also select to close a message. Make each touchscreen selection a separate action. Parent Topic: IntroductionHomeIntroductionTouchscreen Tips
