Data Fields
Some data fields require ANT‍+® accessories to display data.
%HRR
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
Average % HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Average Cadence
The average cadence for the current activity.
Average Ground Contact Time
The average amount of ground contact time for the current activity.
Average HR
The average heart rate for the current activity.
Average HR % Max.
The average percentage of maximum heart rate for the current activity.
Average Pace
The average pace for the current activity.
Average Speed
The average speed for the current activity.
Average Vertical Oscillation
The average amount of vertical oscillation for the current activity.
Cadence
The number of steps per minute for running or the number of full revolutions of the crank arm for cycling.
Calories
The amount of total calories burned.
Distance
The distance traveled for the current track or activity.
Elevation
The altitude of your current location above or below sea level.
Ground Contact Time
The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
HR %Max.
The percentage of maximum heart rate.
HR Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Lap Cadence
The average cadence for the current lap.
Lap Distance
The distance traveled for the current lap.
Lap Ground Contact Time
The average amount of ground contact time for the current lap.
Lap HR
The average heart rate for the current lap.
Lap HR %Max.
The average percentage of maximum heart rate for the current lap.
Lap Pace
The average pace for the current lap.
Laps
The number of laps completed for the current activity.
Lap Speed
The average speed for the current lap.
Lap Time
The stopwatch time for the current lap.
Lap Vertical Oscillation
The average amount of vertical oscillation for the current lap.
Last Lap Distance
The distance traveled for the last completed lap.
Last Lap Pace
The average pace for the last completed lap.
Last Lap Speed
The average speed for the last completed lap.
Last Lap Time
The stopwatch time for the last completed lap.
Pace
The current pace.
Speed
The current rate of travel.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Time of Day
The current time of day based on your current location and time settings (format, time zone, daylight saving time).
Timer
The stopwatch time for the current activity.
Training Effect
The current impact (1.0 to 5.0) on your aerobic fitness.
The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
Copyright © Garmin. All rights reserved.GUID-281F05D9-D51E-4CD6-9D43-C10041A6C65B v5
