Tips for Missing Running Dynamics Data If running dynamics data does not appear, you can try these tips. Make sure you have the HRM-Run™ accessory. The HRM-Run accessory has on the front of the module. Pair the HRM-Run accessory with your Forerunner® again, according to the instructions. If the running dynamics data display zeros, make sure the HRM-Run module is worn right-side up. NOTE: Ground contact time appears only while running. It cannot be calculated while walking. Parent Topic: Running DynamicsHomeANT+ SensorsPutting On the Heart Rate MonitorRunning DynamicsTips for Missing Running Dynamics Data
