Setting a Recurring Alert
A recurring alert notifies you each time the device records a specified value or interval. For example, you can set the device to alert you every 30 minutes.
- Select .
- Select Time, Distance, or Calories.
- Turn on the alert.
- Select Frequency, and enter a value.
Each time you reach the alert value, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds).
Parent Topic: Alerts
