Setting Walk Break Alerts
Some running programs use timed walking breaks at regular intervals. For example, during a long training run, you can set the device to alert you to run for 4 minutes, and then walk for 1 minute, and repeat. Auto Lap® functions correctly while you are using the run/walk alerts.
  1. Select > Settings > Activity Settings > Alerts > Run/Walk > Status > On.
  2. Select Run Time, and enter a time.
  3. Select Walk Time, and enter a time.
Each time you reach the alert value, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds).
Copyright © Garmin. All rights reserved.GUID-281F05D9-D51E-4CD6-9D43-C10041A6C65B v5
