Setting Range Alerts
A range alert notifies you when the device is above or below a specified range of values. For example, if you have an optional heart rate monitor, you can set the device to alert you when your heart rate is below zone 2 and over zone 5 (Setting Your Heart Rate Zones).
  1. Select > Settings > Activity Settings > Alerts.
  2. Select the type of alert.
    Depending on your accessories, the alerts may include heart rate, pace, and cadence.
  3. Turn on the alert.
    For example, you must turn on the heart rate high alert before you can select a zone or enter a custom heart rate value.
  4. Select a zone or enter a value for each alert.
Each time you exceed or drop below the specified range, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds).
Copyright © Garmin. All rights reserved.GUID-281F05D9-D51E-4CD6-9D43-C10041A6C65B v5
