Before you can update your device software, you must have a
Garmin Connect™ account, and you must download the
Garmin Express™ application.
Connect the device to your computer using the USB cable.
When new software is available, the
Garmin Express application sends it to your device.
Follow the on-screen instructions.
Do not disconnect your device from the computer while the
Garmin Express application downloads the software.
NOTE:
If you have already used the
Garmin Express application to set up your device with
Wi‑Fi® networks, the
Garmin Connect application can download software updates to your device automatically when it connects using a
Wi‑Fi network.
TIP:
If you are having trouble updating the software with the
Garmin Express application, you may need to upload your activity history to the
Garmin Connect application and delete your activity history from the device. This should provide sufficient memory space for the update.
