To use the connected features of the
Edge® device, it must be paired directly through the
Garmin Connect™ Mobile app, instead of from the
Bluetooth® settings on your smartphone.
From the app store on your smartphone, install and open the
Garmin Connect Mobile app.
Hold
to turn on the device.
The first time you turn on the device, you will select the device language. The next screen prompts you to pair with your smartphone.
TIP:
You can select
to manually enter pairing mode.
Select an option to add your device to your
Garmin Connect account:
If this is the first device you have paired with the
Garmin Connect Mobile app, follow the on-screen instructions.
If you have already paired another device with the
Garmin Connect Mobile app, from the
or
menu, select
, and follow the on-screen instructions.
After you pair successfully, a message appears, and your device syncs automatically with your smartphone.
