Using Cycling Dynamics
Before you can use cycling dynamics, you must pair the Vector™ power meter with your device (Pairing Your ANT‍+ Sensors).
NOTE: Recording cycling dynamics uses additional device memory.
  1. Go for a ride.
  2. Scroll to the cycling dynamics screen to view your power phase data Callout number one, total power Callout number two, and platform center offset Callout number three.
    Cycling dynamics data
  3. If necessary, select Data Fields to change a data field (Customizing the Data Screens).
    NOTE: The two data fields at the bottom of the screen Callout number four can be customized.
You can send the ride to the Garmin Connect™ Mobile app to view additional cycling dynamics data (Sending Your Ride to Garmin Connect).
Copyright © Garmin. All rights reserved.GUID-D6095C01-0ACF-465B-AB5B-DC6A9AA3B6A3 v2
