Installing the Out-Front Mount
- Select a secure location to mount the Edge® device where it does not interfere with the safe operation of your bike.
Use the hex key to remove the screw
from the handlebar connector
Place the rubber pad around the handlebar:
If the handlebar diameter is 25.4 mm, use the thicker pad.
If the handlebar diameter is 31.8 mm, use the thinner pad.
- Place the handlebar connector around the rubber pad.
Replace and tighten the screw.
NOTE: Garmin® recommends tightening the screw so the mount is secure, with a maximum torque specification of 7 lbf-in. (0.8 N-m). You should check the tightness of the screw periodically.
Align the tabs on the back of the
Edge device with the bike mount notches
- Press down slightly and turn the Edge device clockwise until it locks into place.
Parent Topic: Introduction
