Displaying a Course on the Map
For each course saved to your device, you can customize how it appears on the map. For example, you can set your commute course to always display on the map in yellow. You can have an alternate course display in green. This allows you to see the courses while you are riding, but not follow or navigate a particular course.
  1. Select Menu > Navigation > Courses.
  2. Select the course.
  3. Select Settings.
  4. Select Always Display to make the course appear on the map.
  5. Select Color, and select a color.
  6. Select Course Points to include course points on the map.
The next time you ride near the course, it appears on the map.
Copyright © Garmin. All rights reserved.GUID-D6095C01-0ACF-465B-AB5B-DC6A9AA3B6A3 v2
