Deleting Files
NOTICE
If you do not know the purpose of a file, do not delete it. Your device memory contains important system files that should not be deleted.
  1. Open the Garmin drive or volume.
  2. If necessary, open a folder or volume.
  3. Select a file.
  4. Press the Delete key on your keyboard.
    NOTE: If you are using an Apple® computer, you must empty the Trash folder to completely remove the files.
Copyright © Garmin. All rights reserved.GUID-D6095C01-0ACF-465B-AB5B-DC6A9AA3B6A3 v2
