Going for a Ride
If your device was packaged with an ANT‍+® sensor, they are already paired and can be activated during initial setup.
  1. Hold Power symbol to turn on the device.
  2. Go outside, and wait while the device locates satellites.
    The satellite bars turn green when the device is ready.
  3. From the home screen, select Enter symbol.
  4. Select an activity profile.
  5. Select Pause and play symbol to start the timer.
    Activity timer data
    NOTE: History is recorded only while the timer is running.
  6. Select Up arrow or Down arrow for additional data screens.
  7. If necessary, select Enter symbol to view menu options such as alerts and data fields.
  8. Select Pause and play symbol to stop the timer.
    TIP: Before you save this ride and share it on your Garmin Connect™ account, you can change the ride type. Accurate ride type data is important for creating bike friendly courses.
  9. Select Save Ride.
Copyright © Garmin. All rights reserved.GUID-D6095C01-0ACF-465B-AB5B-DC6A9AA3B6A3 v2
