Following a Segment From Garmin Connect
Before you can download and follow a segment from Garmin Connect™, you must have a Garmin Connect account (Garmin Connect).
  1. Connect the device to your computer using the USB cable.
    NOTE: If you are using Strava™ segments, your favorite segments are transferred automatically to your device when it is connected to Garmin Connect Mobile or your computer.
  2. Go to connect.garmin.com.
  3. Create a new segment, or select an existing segment.
  4. Select Send to Device.
  5. Disconnect the device, and turn it on.
  6. Select Menu > Training > Segments.
  7. Select the segment.
  8. Select Ride.
Copyright © Garmin. All rights reserved.GUID-D6095C01-0ACF-465B-AB5B-DC6A9AA3B6A3 v2
