Barometer Settings
Hold UP, and select .
- Calibrate
Allows you to manually calibrate the barometer sensor.
- Plot
Sets the time scale for the chart in the barometer widget.
- Storm Alert
Sets the rate of barometric pressure change that triggers a storm alert.
- Watch Mode
Sets the sensor used in watch mode. The Auto option uses both the altimeter and barometer according to your movement. You can use the Altimeter option when your activity involves changes in altitude, or the Barometer option when your activity does not involve changes in altitude.
- Pressure
Sets how the device displays pressure data.
Parent Topic: Sensors Settings
