Tips for Missing Running Dynamics Data If running dynamics data does not appear, you can try these tips. Make sure you have a running dynamics accessory, such as the HRM-Run™ accessory. Accessories with running dynamics have on the front of the module. Pair the running dynamics accessory with your D2™ device again, according to the instructions. If the running dynamics data display shows only zeros, make sure the accessory is worn right-side up. NOTE: Ground contact time and balance appears only while running. It is not calculated while walking. Parent Topic: Running Dynamics
Tips for Missing Running Dynamics Data If running dynamics data does not appear, you can try these tips. Make sure you have a running dynamics accessory, such as the HRM-Run™ accessory. Accessories with running dynamics have on the front of the module. Pair the running dynamics accessory with your D2™ device again, according to the instructions. If the running dynamics data display shows only zeros, make sure the accessory is worn right-side up. NOTE: Ground contact time and balance appears only while running. It is not calculated while walking. Parent Topic: Running DynamicsHomeHeart Rate FeaturesRunning DynamicsTips for Missing Running Dynamics Data
