Customizing the Widget Loop You can change the order of widgets in the widget loop, remove widgets, and add new widgets. Hold UP. Select Settings > Widgets. Select a widget. Select an option: Select Reorder to change the location of the widget in the widget loop. Select Remove to remove the widget from the widget loop. Select Add Widgets. Select a widget. The widget is added to the widget loop. Parent Topic: Widgets
Customizing the Widget Loop You can change the order of widgets in the widget loop, remove widgets, and add new widgets. Hold UP. Select Settings > Widgets. Select a widget. Select an option: Select Reorder to change the location of the widget in the widget loop. Select Remove to remove the widget from the widget loop. Select Add Widgets. Select a widget. The widget is added to the widget loop. Parent Topic: WidgetsHomeCustomizing Your DeviceWidgetsCustomizing the Widget Loop
