Showing and Hiding Map Data
If you have multiple maps installed on your device, you can choose the map data to show on the map.
  1. Select Start > Map.
  2. Hold UP.
  3. Select the map settings.
  4. Select Map > Configure Maps.
  5. Select a map to activate the toggle switch, which shows or hides the map data.
Copyright © Garmin. All rights reserved.GUID-ECA243A1-69AF-4270-B1F5-E51E77E9EBC9 v4
