Routing Settings
You can change the routing settings to customize the way the device calculates routes for each activity.
Hold UP, select Settings > Activities & Apps, select an activity, select the activity settings, and select Routing.
Activity
Sets an activity for routing. The device calculates routes optimized for the type of activity you are doing.
Courses
Sets how you navigate courses using the device. Use the Follow Course option to navigate a course exactly as it appears, without recalculating. Use the Use Map option to navigate a course using routable maps, and recalculate the route if you stray from the course.
Calculation Method
Sets the calculation method to minimize the time, distance, or ascent in routes.
Avoidances
Sets the road or transportation types to avoid in routes.
Type
Sets the behavior of the pointer that appears during direct routing.
Copyright © Garmin. All rights reserved.GUID-ECA243A1-69AF-4270-B1F5-E51E77E9EBC9 v4
