Before you can view running dynamics, you must put on a running dynamics accessory, such as the
HRM-Run™ accessory, and pair it with your device (Pairing Your Wireless Sensors). If your
D2™ Charlie was packaged with the accessory, the devices are already paired, and the
D2 Charlie is set to display running dynamics data screens.
Select an option:
If your running dynamics accessory and
D2 Charlie device are already paired, skip to step 7.
D2 Charlie device are not already paired, complete all the steps in this procedure.
Hold
UP.
Select
Select an activity.
Select the activity settings.
Select
Select a running dynamics data screen.
NOTE:
The running dynamics screens are not available for all activities.
Go for a run (Starting an Activity).
Select
UP or
DOWN to open a running dynamics screen to view your metrics.
