Calibrating the Barometer
Your device was already calibrated at the factory, and the device uses automatic calibration at your GPS starting point by default. You can manually calibrate the barometer if you know the correct elevation or the correct sea level pressure.
- Hold UP.
- Select .
Select an option:
To enter the current elevation or sea level pressure, select Yes.
To calibrate automatically from your GPS starting point, select Use GPS.
Parent Topic: Barometer Settings
