Using the Relaxation Timer You can use the relaxation timer to perform a guided breathing exercise. Swipe to view the health stats widget. Select Stress Level. Tap the touchscreen. Select to start the relaxation timer. Follow the on-screen instructions. The watch vibrates, signaling you to breathe in or out (Setting the Vibration Level). Parent Topic: Heart Rate Variability and Stress Level
Using the Relaxation Timer You can use the relaxation timer to perform a guided breathing exercise. Swipe to view the health stats widget. Select Stress Level. Tap the touchscreen. Select to start the relaxation timer. Follow the on-screen instructions. The watch vibrates, signaling you to breathe in or out (Setting the Vibration Level). Parent Topic: Heart Rate Variability and Stress LevelHomeWidgetsHeart Rate Variability and Stress LevelUsing the Relaxation Timer
