Waking the Watch
The Lily® 2 watch automatically wakes when you interact with it while it's powered on.
NOTE: You must plug the watch into a power source if it is completely powered off (Turning On and Off the Watch).
  1. To turn on the screen, select an option:
    • Rotate and lift your wrist toward your body.
    • Double-tap the touchscreen 1.
    Front view of the device with a callout
  2. To turn the screen off, rotate your wrist away from your body.
    NOTE: The screen turns off when not in use. When the screen is off, the watch is still active and recording data.
GUID-C2B794A7-F2FB-456B-B090-69C0111C43CB v6
February 2026
