Setting a Recurring Alert
A recurring alert notifies you every time the device records a specified value or interval. For example, you can set the device to alert you every 30 minutes.
- From the home screen, select .
- Select an activity profile.
- Select Alerts.
- Select Time, Distance, or Calorie.
- Turn on the alert.
- Enter a value.
Select
Each time you reach the alert value, a message appears. The device also beeps if audible tones are turned on (Setting the Device Tones).
Parent Topic: Alerts
