NOTE:
If you do not have a
GSC™ 10, you can skip this task.
Both magnets must be aligned with their respective indication lines for the
Edge® to receive data.
Place the
GSC 10 on the rear chain stay (on the side opposite the drive train).
If necessary, place the flat rubber pad
or the triangle-shaped rubber pad between the
GSC 10 and the chain stay for stability.
Loosely attach the
GSC 10 using two cable ties
Attach the pedal magnet
to the crank arm using the adhesive mount and a cable tie
Unscrew the spoke magnet
from the plastic piece.
Place the spoke in the groove of the plastic piece, and tighten it slightly.
The spoke magnet can face away from the
GSC 10 if there is not enough room between the sensor arm and the spoke. The spoke magnet must line up with the indication line
on the sensor arm.
Loosen the screw
on the sensor arm.
Move the sensor arm to within 5 mm of the spoke magnet.
You can also tilt the
GSC 10 closer to either magnet to improve alignment.
Select
Reset
on the
GSC 10.
The LED turns red, then green.
Pedal to test the sensor alignment.
The red LED blinks each time the pedal magnet passes the sensor. The green LED blinks each time the spoke magnet passes the sensor arm.
NOTE:
The LED blinks for the first 60 passes after a reset. Select
Reset again if you require additional passes.
When everything is aligned and working correctly, tighten the cable ties, the sensor arm, and the spoke magnet.
Garmin® recommends that the torque is 1.9 to 2.4 lbf-in. (0.21 to 0.27 N-m) to ensure a water tight seal on the
GSC 10 sensor arm.
