Temperature Readings
The device may display temperature readings that are higher than the actual air temperature if the device is placed in direct sunlight, held in your hand, or is charging with an external battery pack. Also, the device will take some time to adjust to significant changes in temperature.
Copyright © Garmin. All rights reserved.GUID-781201CC-89A5-4DC1-9225-CD079631E23B v3
