Pairing Your ANT‍+ Sensors
Before you can pair, you must put on the heart rate monitor or install the sensor.
Pairing is the connecting of ANT‍+® wireless sensors, for example, connecting a heart rate monitor with your Garmin® device.
  1. Bring the device within range (3 m) of the sensor.
    NOTE: Stay 10 m away from other ANT‍+ sensors while pairing.
  2. From the home screen, select > Bike Profiles
  3. Select a profile.
  4. Select a sensor.
  5. Enable the sensor, and select Search.
    When the sensor is paired with your device, the sensor status is Connected. You can customize a data field to display sensor data.
Copyright © Garmin. All rights reserved.GUID-781201CC-89A5-4DC1-9225-CD079631E23B v3
