Updating Your Bike Profile
You can customize 10 bike profiles. The device uses the bike weight, odometer value, wheel size, and crank length to calculate accurate ride data.
  1. From the home screen, select Edge device setup symbol > Bike Profiles.
  2. Select an option:
    • Select a profile.
    • Select Plus symbol to add a new profile.
  3. Select the name of the bike.
  4. If necessary, edit the name, image, and other settings for the profile.
  5. If you are using a speed sensor, cadence sensor, or power sensor, select an option:
    • Select Wheel Size > Automatic to calculate your wheel size using GPS distance.
    • Select Wheel Size > Custom to enter your wheel size. For a table of wheel sizes and circumferences, see Wheel Size and Circumference.
    • Select Crank Length > Automatic to calculate your crank length using GPS distance.
    • Select Crank Length > Custom to enter your crank length.
    All your changes are saved to the active profile.
Copyright © Garmin. All rights reserved.GUID-781201CC-89A5-4DC1-9225-CD079631E23B v3
