Pairing a Heart Rate Monitor Before you can pair, you must put on the heart rate monitor. Bring the device within range (3 m) of the heart rate monitor. NOTE: Stay 10 m away from other ANT+® sensors while pairing. Select > Heart Rate > Enable > Search. When the heart rate monitor is paired with your device, the sensor status is Connected. Parent Topic: ANT+ Sensors
Pairing a Heart Rate Monitor Before you can pair, you must put on the heart rate monitor. Bring the device within range (3 m) of the heart rate monitor. NOTE: Stay 10 m away from other ANT+® sensors while pairing. Select > Heart Rate > Enable > Search. When the heart rate monitor is paired with your device, the sensor status is Connected. Parent Topic: ANT+ SensorsHomeANT+ SensorsPairing a Heart Rate Monitor
