Adjusting an Auto Guidance Path
- Select Nav Info > Routes.
Select a path, and select
Edit > Adjust Path.
TIP: When navigating an Auto Guidance path, select the path on the navigation chart, and select Adjust Path.
- Select a location on the path.
Select an option:
On device with keys, use the arrow keys.
On device with touchscreens, drag the path.
- If necessary, select a point, and select Remove.
- Select Done.
Parent Topic: Auto Guidance
