Adding a Vehicle Profile
You should add a vehicle profile for each camper to be used with your Camper 770 device.
- Select .
Select an option:
To add a motorhome with a permanently attached camper, select Motorhome.
To add a camper pulled behind a vehicle using a standard hitch, select Trailer.
To add a camper pulled behind a truck using a fifth-wheel hitch, select Fifth Wheel.
- Follow the on-screen instructions to enter the vehicle characteristics.
After you add a vehicle profile, you can edit the profile to enter additional detailed information, such as the vehicle identification number or trailer number.
Parent Topic: Vehicle Profiles
