Map and Software Updates
For the best navigation experience, you should keep the maps and software on your device up to date. Map updates ensure your device has the latest available map data. Software updates provide improvements to features and performance.
You can update your device using two methods.
  • You can connect the device to a Wi‑Fi® network to update directly on the device (recommended). This option allows you to update your device conveniently without connecting it to a computer.
  • You can connect the device to a computer and update it using the Garmin Express™ application. This option allows you to install map data onto a memory card if the updated maps are too large to fit on the internal storage.
Copyright © Garmin. All rights reserved.GUID-4CAA754F-AC8A-49C0-969A-92878A0FDE25 v3
