Receiving Notifications
WARNING
Do not read or reply to notifications while driving.
Before your Camper 770 device can receive notifications, you must connect it to your smartphone and to the Smartphone Link app.
From most pages, a popup appears when the device receives a notification from your smartphone. If the device is moving, you must verify you are a passenger and not the driver before you can view notifications.
NOTE: If you are viewing the map, notifications appear in a map tool.
  • To ignore a notification, select OK.
    The popup closes, but the notification remains active on your phone.
  • To view a notification, select View.
  • To listen to the notification, select View > Play.
    The device reads the notification using text-to-speech technology. This feature is not available for all languages.
  • To perform additional actions, such as dismissing the notification from your phone, select View, and select an option.
    NOTE: Additional actions are available for only some notification types and must be supported by the app generating the notification.
Copyright © Garmin. All rights reserved.GUID-4CAA754F-AC8A-49C0-969A-92878A0FDE25 v3
