Backup Camera Settings
The backup camera settings allow you to manage paired Garmin® backup cameras and camera settings. This menu appears on your navigation device only when the device is connected to a wireless camera receiver cable. See the owner's manual for your backup camera for detailed information about pairing cameras and camera settings. Go to garmin.com/backupcamera to purchase a Garmin backup camera.
Select , and select a paired camera.
- Unpair
Removes the paired camera. You must pair the camera again before you can view it using this device and cable.
- Rename
Allows you to rename the paired camera.
- Guidance Lines
Shows or hides guidance lines and allows you to adjust the position of the guidance lines.
Parent Topic: Camper 770 Settings
