Setting a Simulated Location
If you are indoors or not receiving satellite signals, you can use the GPS simulator to plan routes from a simulated location.
  1. Select Settings > Navigation > GPS Simulator.
  2. From the main menu, select View Map.
  3. Tap the map twice to select an area.
    The address of the location appears at the bottom of the screen.
  4. Select the location description.
  5. Select Set Location.
Copyright © Garmin. All rights reserved.GUID-4CAA754F-AC8A-49C0-969A-92878A0FDE25 v3
