Location Search Results on the Map
You can view the results of a location search on the map instead of in a list.
From the location search results, select
. The nearest location appears at the center of the map, and basic information about the selected location appears at the bottom of the map.
![Search results map with callouts](GUID-74B11C0C-CCDE-4765-A118-952DD95BEC3B-high.jpg)
Drag the map to view additional search results. |
Additional search results. Select to view another location. |
Selected location summary. Select to view detailed information about the selected location. |
Select to start navigating to the location using the recommended route. |
Select to view the search results in a list. |
Parent Topic: Location Search Results
