Adding Propane Tanks
When you add your propane tanks to your vehicle profile, the device avoids routing through areas with propane tank restrictions that may affect your route. The device also alerts you when you approach areas that require you to shut off your propane tanks.
Select
- Select the vehicle profile to edit.
- Select .
- Enter the weight of the propane tank, and select Save.
Parent Topic: Editing a Vehicle Profile
