The device does not charge in my vehicle
  • Check the fuse in the vehicle power cable (Changing the Fuse in the Vehicle Power Cable).
  • Verify the vehicle is turned on and is supplying power to the power outlet.
  • Verify the interior temperature of the vehicle is within the charging temperature range indicated in the specifications.
  • Verify the fuse is not broken in the vehicle power outlet.
Copyright © Garmin. All rights reserved.GUID-4CAA754F-AC8A-49C0-969A-92878A0FDE25 v3
