Changing Handedness
The TruSwing™ device uses your handedness to calculate the correct swing analysis data. You can use your Approach® device to change your handedness at any time.
From the
menu on your Approach device, press the device key to view the menu.
- Select Golf Swing.
- Select your handedness.
Parent Topic: TruSwing
